Predstavljam vam še eno novost, katera se obeta v naši ponudbi v kratkem: Ročno narejene britve
MEDUSA! Vsaka je unikat.
Medusa Straight Razor
Is a pleasure for me describe
Medusa brand and their straight razors.
Medusa Group was officially born on 30 May 2011. It is composed by two italian people:
Franco (Franz Kleber) and Andrea (Aldebaran) .Franco is a mechanical technician, Andrea is a
student of engineering(nuclear engineering)/worker,Ordinary Member of the A.I.M. (Italian
Metallurgy Association.Like an hobby they build straight razors,but they are the first in the world
to use third generation of stainless steels powders metallurgy, for example, CPMS30V,
CPMS125V, CPMS35VN to build straight razors.One of their work is exposed at the Science and
Technology Museum in Milan.
Here is a list of their works
http://www.ilrasoio.com/viewtopic.php?f ... 541#p14541
Crucible S.PA. has created for them the 6 mm. thick steel in CPMS35VN.
Medusa along with the Crucible S.P.A., Chris Reeve, Fantoni SRL, Eng. Emidio D'Astolfo and
Stefano Raffa built the first straight razor in the world in CPMS35VN (third generation of powder
metallurgy steel)with cryogenic treatment.
We are performed the following industrial processes:
1.Steel was cut with the laser
2.The back has been processed industrially
3.Jimps above and below the tang with wire EDM
4.Milling around the template to remove decarburization.
5.Heat treatment (innovative treatment, six thermal vacuum cycles, including cryogenics;
impossible, however, to be implemented handcrafted the thermal process on such a type of steel).
6.Writing made with laser.
Operations carried out by hand
1.First Grinding
2.Tang creation
3.Second Grinding
4.Sharpening
5.Forged washers and pins to connect the handles to the shanks
6.Handles and stabilizations
This kind of straight razors modeled by the figure of Novodur, have a stabilizer, the height of the
blade is about 8/8, square point, the hollow of grinding ranges is about from 1/4 hollow to half
hollow .
There is a video on youtube about
Medusa/Fantoni CPMS35VN straight razor
https://www.youtube.com/watch?feature=p ... HsNSdFiAxM
and many positive comments ,and photos on a French Forum and Italian Forum
http://coupechouclub.cultureforum.net/t ... ial#359444
http://www.ilrasoio.com/viewtopic.php?f=9&t=5857
thank you for your attention,Best Reguards,Sincerely,
TVB Shaving
hosting immagini
upload
