Kdaj je pena "prava"?
Še en odličen vodič za uporabnike mil: https://www.youtube.com/watch?v=_4zESTQWDuw
Re: Kdaj je pena "prava"?
Da ti steče po vratu mora biti pa res že zelo mokra pena.
Pozabili smo dodati še tole:
http://wiki.badgerandblade.com/Lathers
Kot že rečeno, zadostno količino mila ali kreme. Pri Prorasu je to 2 cm kreme. Pomembno je predvsem tole:
The lather's sweet spot
The first time you use a new cream: shake the brush 4 or 5 times. Get an almond size dollop (sometimes called a "snurdle") of cream and wipe it in the breech of the brush. Whip the lather for at least 30-45 seconds (like you're beating eggs) and see what the lather looks and feels like. Take a little between two fingers and feel it. Now add about half a teaspoon of water and whip another 30 seconds or so. Continue doing this over and over, feeling the cream each time and paying attention to what it looks like and feels like when you're whipping it. Continue doing this until the lather is obviously over saturated (very thin, large bubbles, won't support itself in a peak, etc.).
Now repeat the whole procedure with the same cream. The "sweet spot" ratio will stay the same, and after a few bowls you'll recognize when the lather is at that sweet spot and at its most lubricating. After 5 or 6 bowls you shouldn't have any problem getting it "sweet" without much hassle.
Note that some soaps and creams require the water to be added slowly, rather than all at once (even if the total amount ends up the same). Also, you may find that you need to add a small amount of hot water to the lather as the shave progresses.
Once you have a rich, thick, and lubricating lather, begin lathering up your face. Some people prefer rubbing it on in circles, others prefer painting it on. Stiffer brushes lend themselves more to circles, while softer ones seem better able to paint. Whatever technique you use, spend more time applying the lather than you think you should. Doing so results in better saturation and also helps the whiskers to stand up better
Dobra pena.
Tale človek deluje smešno, ampak to je za mene prvi video, ki dejansko govori, kakšna pena mora biti za dobro zaščito kože in za ne-izsuševanje. Torej, čim bolj drseče, kar se dobi s čim več vode. Obenem pa to pomeni, da bo minimalno izsušilo kožo.
Zato prosim zainteresirane za mokro britje, da si posnetek ogledate pozorno od začetka do konca.
Če se pena prehitro suši, ni dovolj vode ali pa niste dovolj zmešali in s tem niste izločili vseh mehurčkov.
To sem opazil pri uporabi Dr,Selby mila.Tudi največji čopič,ki ga imam na zalogi je imel težave z količino vode,ki ga to milo potrebuje.Možakarju na posnetku pa se vidi,da ima določeno kilometrino v uporabi DE,SE itd.Očitno dobro ve o čem govori.
